Anyone with S2 brake squeal problems?
Old 05-07-2006, 01:42 PM
Mione
Mione's Avatar
Default Anyone with S2 brake squeal problems?
I have a 04 reg which has done about 31000 miles, and in the past 2 weeks I am getting quite a lot of "squealy" noise when I brake. Most noticeable at pretty slow speeds, coming up to junctions. (It might be that I cannot hear it at higher speeds.) I thought it might be slightly uneven brake pad wear, which would sort itself out after a few days, but the noise is still there. Seems to be no issue with brake performance, just this noise which is a bit embarrassing as it make the car sound ropey. Is this common in S2s or should I get it checked out?
Old 05-07-2006, 01:59 PM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Spend 10 minutes to take the wheels off and inspect the pads?
Old 05-07-2006, 02:04 PM
Mione
Mione's Avatar
Cheers - yes that would be an idea... just being a bit of a girl avoiding that, and thought I'd check to see if it was a common problem first.
Old 05-07-2006, 02:58 PM
98CoupeV6
98CoupeV6's Avatar
Brake squeal is typically associated with worn pads (or cold performance pads, but that's not the issue here). If you were hard on your brakes in the 31k miles then they certainly could be worn down.
Old 05-11-2006, 10:28 PM
killers2k
killers2k's Avatar
sounds like it could be 2 things
a) your brakes are worn and you are hearing the alarm on ur pad when u brake.
or
b) your brakes are crystalized and are going to squeal regardless meaning they got pretty hot at some point and when they cooled they sorta glazed over..
Old 05-13-2006, 06:01 AM
Mione
Mione's Avatar
Thanks guys. Fairly sure I have not been too hard on the brakes (avoid using them actually - esp in the rain!) but I will get it checked.
