help odomoter sticks i have to bang dash to unstick
does anyone know how to fix this example. 121999 it sticks and i have to hit the dash to get it unstuck whenever it about to change a thenth it sticks
it's electronic (no cable) sometimes they stick a bit and will work itself out on when the number advances. I wouldn't spray anything in it as you can make it worse or a mess.
sounds like the gears in the odometer are misaligned you might be able to pull the speedo out of the gauge and try to realign them as it's all mechanical with a steper motor controlling it ..
try resetting the maintenance required, there was a bulletion about this problem happening if the button isin't pushed in all the way the last time it was reset. if not then it's replacement time.
