ignition inquiry
ignition inquiry
i was reading on here about ignition wires and found an article about stock wires being better. is this true? stock ignition wires do not misfire and are more consistent than aftermarket replacement wires, especially in the VTEC range. my question is if this is true? does that mean Honda OEM Spark Plugs create the bigger spark? what if you are tuning your car and running a turbo or nitrous oxide? does the stock OEM Honda wire still prove as effective?
Chidori-chan :love:
aftermarket wires create more spark, but u should stick to OEM wires unless if u're going for big horsepower (turbo or NA setup)...the OEM FPR, spark plug and wires are good enough for bolt-ons and such
