engine work question F23
can someone tell me what the parts listed on #9 do? and is the package worth the price?
http://importperformanceparts.net/im...pek-honda.html
lots and lots of fail
1 Post
- Includes: Kit #/Price
- F23 A1/4/5 86mm Complete Gasket Set
- Cometic Head Gasket
- ROSS/Wiseco Pistons
- (86, 86.5, 87, 88mm bore) and
- (8.5-1, 9.5-1, 10.5-1, 11.1-1 comp ratio)
- Performance Rings
- Performance Wrist Pins
- TOGA HP Main Bearings
- TOGA HP Rod Bearings
- Thrust Washers
- Timing Belt
- Expansion Plugs
What exactly do you need explained? I have no idea why you'd spend $1000 on this crap unless you're going to be putting a turbocharger on it and going to shows or drag races or something, but go for it if you want.
well i'm not sure what those things do and the point in changing them. i want to know if those are supposed to spin out more horsepower? or are they just stronger so a high boost from a T/C or N2O will be supported.
1 Post
Originally Posted by 98CoupeV6
You wouldn't see anything but an oddly performing engine if you bought that kit without a controllable ecu and a professional tuner.
1 Post
LoL....oddly performing...thanks for the response. you got any links you can point me to so i can read up about tuning and internal work?
