05 accord will not start
Hi i have a 05 accord lx 2.4l 4cyl, that will not start. (warranty expired )
i was pulling in my driveway yesturday and the car just quit running).
i tryed to restart it but it wont start,it cranks but it will not start. I noticed while trying to restart the car that my check engine light & battery light will not come on when you turn the key from off to on/run,all other light come on. I checked all the fuses they seem to be fine no blown fuses, one problem i have that i lost the underhood pdb/fuse box cover i have no way off knowing which fuse is pcm fuse(does any one have the fuse box diagram)
DO 05 accords have main fuel pump relay, possible that it burned up,
some one please help me.
Older Honda Fanatic
Its really hard to say what it is... theres a ton of things that it could be... especially since its a theft recovery vehicle, who knows what was torn apart...
DO NOT DO THAT! My Nissan Altima's alternator was bad and they checked it that way and screwed up the cars computer, everything after that went downhill, thats how they would check on the older model cars but not on the newer model cars. Big no-no. I wound up selling the car.
if the starter is turning then it's NOT the battery as I have yet see a dead battery turn the starter , first check the dash lights does the green key light (immobilizer light) blink or doesn't come on , second since the check engine light doesn't come on then go off I would check all the fuses in each fuse box one by one as sometimes they have ones that does power the ecu or injectors but doesn't say it .
