vibrating headlight
vibrating headlight
hi guys today i noticed my 98 accords light beam vibrating....i pop the hood and start moving the light bullb it was pretty tight but i noticed the reflector part inside the headlight moving loose..i pulled the bullb out stuck my finger in the hole and pulled reflector back it poped in, but it still moves and my light beam vibrates (stock headlight)...and by the way its only the bottom part that feels loos the top part is fine..does anyone know how to fix this? or do i need a new headlight??????
you can pull the whole light out and put the light in the oven and pull the light appart anf tighten or glue the reflector as you have nothing to loose since your replaceing it anyways .
