H22 in 02 Accord
Old 02-26-2006, 03:57 PM
b18c1_hatch
b18c1_hatch's Avatar
Default H22 in 02 Accord
how hard would it be to do this swap.i no its common but is it just bolt in and a little bit of wiring. Do you use the the stock mounts on it. just wondering. IT was a pain doing it in my buddys civic i hope its easier doing it in this.
Old 02-27-2006, 01:04 PM
AcuraFanatic
AcuraFanatic's Avatar
It's a pain in the ass, I've seen it done but it's nowhere near as straight forward as an H22 into a 5th gen or 4th gen Accord. I believe you can use the stock mounts but I am not sure.
Honestly unless you plan on boosting the engine it's really not worth it. The 6th gen Accord is a pretty heavy car.
Old 02-27-2006, 02:51 PM
skabone69
skabone69's Avatar
I just toasted my F23 and looked into it. I was quoted $6000 for everything from 2 local reputable shops. I'm just going to stick with the stock engine, I found one with 19K for $500, and I'm going to be paying around $1200 for the stock swap, including the price of the motor. If you have the cash do the swap, I know of one friend with an OBDI H22 and he loves it, and I know of another friend that is in the process of swaping in an OBDII H22. there are some issues you have to deal with. I hear the wiring is a pain in the ass, and you have to modify one of the motor mounts. good luck if you attempt the swap.
Old 02-27-2006, 06:13 PM
blacknight07601
blacknight07601's Avatar
I don't think the swap is a hard as people say. I'm curious into doing it also.
As far as weight. According to cars.com, the 2001 Prelude and the 2002 Accord EX 4cyl weigh close to the same
Old 03-01-2006, 04:35 AM
b18c1_hatch
is it easier to put it into a 02 accord then a EG civic. If it is then it woult be a problem. ive done it in a eg well helped and i was a pain in the ass.
Old 03-01-2006, 06:20 AM
98CoupeV6
lots and lots of fail
98CoupeV6's Avatar
Someone on this board has done it, search
Old 03-01-2006, 06:21 AM
98CoupeV6
98CoupeV6's Avatar
How'd you do that?
Old 03-01-2006, 07:25 AM
skabone69
skabone69's Avatar
Originally Posted by 98CoupeV6
How'd you do that?
high sustained RPM thru the mountians on the way to Vegas. my engine has also been burning about a quart of oil between oil changes for a little while now. Cylinder #1 had a misfire and I lost compression in that cylinder. luckly I found a replacement motor with 19K on it for $500. so pretty much I'm getting a new F23 thrown in my car. no car payments > *
Old 03-01-2006, 07:35 AM
98CoupeV6
98CoupeV6's Avatar
The engine should easily be able to handle the RPMs though, and very easily. They're durability tested under much worse than that. It must have been oil starvation that got it?
Old 03-01-2006, 08:00 AM
skabone69
skabone69's Avatar
well I put a quart of oil in it before I left on my trip. I did just recently switch from dino oil to synthetic because I was burning oil. it didn't help in my oil consumption. oh well, at least I'll have a new motor to beat on. it should be able to take my abuse for 100K at least.
