What transmission is udes in the S2000?
Hello, forum!
I was wondering what tranmission is used in the S2000. Is it similar to other Honda or Acura designs? (I assume not, being front engine, rear drive...) Does anyone know who makes it? Is it similar to a T-56?
And what engine is used in the S2000? (B20-something?)
All info would be very helpful. Thanks!
lots and lots of fail
1 Post
Honda makes the transmission. They make all their transmissions. It is completely different from any other Honda tranny since the S2000's motor (the F20C) is longitudinally mounted....or whatever way it is that's from front to back. Maybe it's transversely? You get my drift. Why? You planning on doing a swap or something? You can't fit the F20C into any H/A without major, MAJOR work to make it RWD...or you can stick it in the trunk and make it MR.
Thanks for your response.
I'm interested in running in the 1.5 to 2.0 liter engine class at Bonneville. I thought a Honda engine would be great for making reliable power, but I want front engine, rear drive for a quick-change rear end. (I'll be running in either streamliner or lakester class.)
Any ideas on what transmissions could mount up to a B18 or B20? Or is that a question for eslewhere on Honda-Acura net?
Thanks again.
Thanks again.
1 Post
Thanks again.
Thanks again.
Chris
Isn't the B20 the engine used in the CR-V that's essentially the same as the B18s, just 2.0 liters instead of 1.8? (I may be wrong...)
But I think I have a bigger problem here... Don't Honda engines spin the "wrong" way for rear wheel drive?
Thanks for the tip, Chris. I'll check out the Engine Tech and a Hybrid forum.
1 Post
Nelson
Other Honda & Acura News
05-24-2012 11:00 AM
mystikalxxtasy
06-16-2006 10:48 AM
su2ny
09-25-2003 07:07 PM
