93 Accord Idleing Rough
Old 02-17-2006, 09:39 AM
texaskreek06
texaskreek06's Avatar
Default 93 Accord Idleing Rough
I bought my accord about a year ago from a friend, who told me it idled really rough when the air conditioner was on and you were in reverse, other then that it was fine. I got it, and sure enough it onl idled rough under those circumstances, however after a few months of driving it, it started idleing rough anytime in reverse and has gotten really bad over time, it also idles alittle rough on and off at other times. Any Ideas???? Not quite sure what to think about it.
Old 02-17-2006, 10:30 AM
semyonlibman
semyonlibman's Avatar
How about tune up: spark plugs, wires, distributor cup?
Old 02-18-2006, 04:42 AM
Cousin It
Cousin It's Avatar
Sounds like your rear motor mount is shot.
Old 02-24-2006, 05:06 PM
texaskreek06
Default fixed it
Well I fixed it, as it turned out i just sprayed some carb. cleaner in the PCV valve and it did the trick. I was actually idling rough because my rpms were at 400 when idling, when after cleaning they were around 650 which is much closer to normal, and it really smoothed down the car.
Old 02-26-2006, 11:04 PM
dirtyjohn
dirtyjohn's Avatar
i forgot what that thing is call its where you have 2 water line running through it.. ITs a sensor with a magnet. well that thing is old change it. and it will fix your problem. spark plugs has nothing to do with rough idling.
Old 02-28-2006, 06:10 PM
used2bedomestic
used2bedomestic's Avatar
IACV. That can get clogged and you can clean it pretty easy! It regulates your idle and you can clean it with carb cleaner!
Try not to get carb cleaner in the coolant tubes!
Old 03-01-2006, 09:45 AM
skylert
skylert's Avatar
I have a 92 Honda Accord LX with intermittent rough idling. Can someone show me with images or provide detail instructions to find the IAVC and the FITV. I have noticed that lately the car seems to run at a higher rpm rate while driving it. Does anyone have advice?
