Help on installing VAFC2 on 01 Accord (H5a)
I got pretty much IG power (red), Engine Revolution Signal (RPM signal) (green), Ground Conductors (black and Brown), Throttle Signal (Gray)..That's all of the wires that i've installed into my ECU connectors' wires. I still have two wires left and it is Orange and Light Blue. In the AFC installation manual, it says that to connect the Orange wire to the VTC cam signal Wire and Light Blue wire to the TDC signal wire. I have no idea what those signal locates on my ECU. On ECU diagram in the manual came with the computer, it shows there's a VTEC solenoid Signal on 25P, and Pressure Signal on 16P, but i don't see the wires that the manual says it supposed to go there. Help. If you have done the same thing to the 6gen Accord 4cyl with VAFC2 and works fine, please post a Diagram up or let me know by email. Thankx
