I need full suspenion upgrading advice?
I am upgradeing the suspension on my 98 integra GSR. By installing Tein super street coil-overs, tein pillow upper mounts, a Integra type R rear sway bar, and a sprint suspenion camber alignment kit. Then pull it on the rack and do the alignment. Any advice or problems I can avoid. Besides buying different brand. My car comes stock with a tower bar so going to leave that alone for now.:driving:
NASA-VA Hyper-Announcer
Originally Posted by KarrNtegGSR
I am upgradeing the suspension on my 98 integra GSR. By installing Tein super street coil-overs, tein pillow upper mounts, a Integra type R rear sway bar, and a sprint suspenion camber alignment kit. Then pull it on the rack and do the alignment. Any advice or things to problems I can avoid. Besides buying different brand. My car comes stock with a tower bar so going to leave that alone for now.:driving:
Well you really do not need the upper pillow mounts and unless your going to be adjusting your camber a lot a camber kit is not really needed either.
Honorary Moderator Alumni
I've run with so much negative camber for years and no problems. My tires last a full season and a half. But I also have 0 toe front and back. Toe wears tires quicker than camber.
Autocross Help Page
Autocross Help Page
thanks
Originally Posted by bnuk
if you are pulling all that apart you might as well do some poly bushings while you are in there.
