taking your advice
taking your advice
Ive posted a couple of times about dropping a type r into my gsr. Everyone i talked to even you guys said to fix up the engine thats already in my car and make it better than the itr, So here i am, at your mercy. I want to make about 290 to 310hp. NA My car has 130k on the motor, where do i start. port polish, bored out, pistons and rods, camshafts/gears, what ever to help me accomplish my goal. thanks alot
yeah, i know that will get me the power i want quick, but still need to build up my engine to handle it, want to be able to drive it everyday and not worring about it breaking.
4-doors ROCK
if you want a high-powered NA motor, you're gonna have to build it up a LOT and increase the compression ratio at the same time...if you're building your motor up to handle a turbo kit, you're gonna do it differently cause you don't want very high compression ratios for turbo setups...so try to decide whether you'd want to stay NA and do a fully built motor like that or instead reenforce your current motor specifically to handle a turbo kit
www.ufc.com
If your looking to get 290-310hp N/A you have a lot of work to do my freind and a lot of money to spend. It can be done, it just cost more. Not sure where you are located either, but an all motor build like that will never pass emissions. If that is not a concern than good luck to you, cause just about everything all motor will have to be done to attain your goal. Stroke, port/polish (max port), pistons (domed), rods, cams (stage 3), IM, intake, header, exhaust, crank, flywheel, clutch, valvetrain...geez that doesn't even sound like enough. I gotta be leaving stuff out. That will probably get you 250. But with that being done, it would be safe to squeeze (NOS) to get to that 290-310 mark. Good luck!!!
On permanent hiatus
Originally Posted by gsr converters
i live on the east coast, wanna go more forced induction than all motor
The Type R motor is so incredibly overhyped. Just rebuild your current motor for boost and run circles around an equally priced Type R motor swap.
