instrumen gauge light cluster dimmed over time?
Old 12-25-2005, 05:43 PM
picard
picard's Avatar
Default instrumen gauge light cluster dimmed over time?
I have an accord 93 4cyl sedan for long time. The gauge clusters lights dimmed over time. It is no longer as bright as when the car was new. Do I have to replace the light bulbs ? Is there an alternative way to fix it?
Old 12-26-2005, 01:59 PM
accordsir86
accordsir86's Avatar
did you check the panel light dimmer switch. maybe the little knob is set to a dimmer level, if not maybe you just need new bulbs
Old 12-26-2005, 06:35 PM
picard
picard's Avatar
I set the knob switch to maximum but the light still dim. Does the instrument cluster use bulb or LED? I am not even certain anymore.
Old 12-26-2005, 07:59 PM
andy2541
andy2541's Avatar
