B-series Transmission Question
Sharkbait OOHAHA!
Will a '90 LS cable tranny bolt right up to a newer '94+ LS motor? I assume it would, but want to ask just to make sure.
In addition to that, Quaife makes an LSD for the LS. Their application chart says '90-00 GS/LS. By looking at Quaife's chart it would seem the same part is designated to work whether it's a hydro or a cable tranny. Has anyone ever installed one on their cable tranny?
Thanks in advance
Thanks in advance
im going to assume a G3 teg.
1. yes it will fit the engine, all bseries trannys r interchangable
2. it will NOT fit the chasis, the G3 chasis is equiped with Hydro tranny stuff (cylinders ect). so u can put it in...but it wont work.
3. if its going into a G2 or any other car with cable tranny stuff, everything is fine
Sharkbait OOHAHA!
Originally Posted by teg92
a 90 cable tranny will bolt up to a 94 LS motor, i have a 96 LS motor and im putting a 91 LS cable tranny on it. What year car is it going on?
Any experience out there on a Quaife LSD installed on an LS cable tranny?
Thanks guys
i think the 89 crx is cable tranny stuff in the chasis...its about 400 i believe for the cable->hydro conversion...not worth it im my opinion.
where r u getting the engine from? hmotorsonline has a LS block for 700, but i dunno if u need everything (ecu, ect) so u might wanna go with the complete change over (check for the price, i forgot), then sell that hydro tranny it comes with and get a cable. unless u wanna get the cable->hyrdo
I
It will bolt right up, and since your car is cable to begin with, it'll be fine. As for the LSD, I'm not sure. I would think the LSD would be different hydro vs cable. You could look for a JDM B16/GSR cable tranny with LSD.
Sharkbait OOHAHA!
I
People like to use the LS gearing in turbo applications for better traction due to longer gears, and longer gears mean you stay in full boost longer. I'd go personally with a GSR tranny, but a cable GSR is hard to find.
