S2000 WHeels....
quote from spa-zz on s2ki boards "Still, IF YOU MUST, you can run the same size WHEEL all around, but not the same size TIRE. You really should run something about 20 to 40 mm wider in the rear. Like 205 front, 225 or 245 rear. To do this, you'll need to find a wheel that could fit those sizes. With a 7.5" width, you could run a 205 in front and a 225 in back, but it's NOT the best idea because one tire will be stretched and the other will be pinched."
