96 accord ignition switch
Old 12-19-2005, 05:20 PM
hiddenman99@yah
hiddenman99@yah's Avatar
Default 96 accord ignition switch
my car was stollen and recovered. I now have to replace it's ignitionn switch. I was able to drive it for a while until the sterring wheel locked-up.(while parked). anyway, does anyone have help onreplaceing the ignition switch????????????///
Old 12-20-2005, 06:03 PM
stereo
stereo's Avatar
just tap out or drill out the 2 breakaway screws and take the lock out until you get the new switch
Old 12-25-2005, 11:10 AM
hiddenman99@yah
Default ignition switch/lock
Hey that sounds easy but I din't have a cordless drill. Do you really think I'll be able to knock a punch through it? Are the bolts aluminum or something? What about chiseling the bolt heads off? That is if the metal is that soft!!!
I'll try again tomorrow >>>>>>>>It sucks not haveing my vehical on , hey it's(Especially on X-mass)
Old 12-26-2005, 12:08 AM
stereo
stereo's Avatar
then use a punch and tap on the screw until it's loose then start on the second one as if you take the first one off the second one will bind or tap one loose and try and bend the bracket out just be carefull not to damage the air bag cable thats under the switch.
