Lockup control Solenoid question
Old 12-18-2005, 07:46 AM
flyromeo3
flyromeo3's Avatar
Default Lockup control Solenoid question
Hi guys, I have a question to ask. I need to change my lockup control solenoid ( A,B ) on my 02 accord 4cyl.
Since the solenoid sits ontop of the tranny housing would it appear that I have to drain the tranny fluid before I change this part?
I have a few bottles of honda tranny fluid so it wouldnt really matter if i do. Just that I prefer not to get under the car in this freezing whether we're having.
Old 12-18-2005, 09:36 PM
TrackMasterz
TrackMasterz's Avatar
Sorry, I can't help you but I do have a question: How do you know that the lock up solenoids are bad? Specifically, what are the symptoms?
Thanks.
Old 12-19-2005, 04:36 AM
flyromeo3
flyromeo3's Avatar
Thanks.
Based on the error code I received from the CEL and the symptoms.
When shifting to 2nd from 1st I feel the torque convertor is locking up all the way. The rest of the gears are fine. It doesnt slip at all. It doesnt feel like its a tranny related problem where the tranny has to get replaced. I took it to pep boyz and r&s strauss ( local car places ) and they got the same error codes and advised me that I should get that solenoid replaced.
I'd rather spend 150 bucks and pray this solves my issue vs. replacing the tranny.
I hope this helps.
Are you having an problem also?
Old 12-19-2005, 02:13 PM
honda guy
honda guy's Avatar
I hate to break it to ya but its not going to fix the problem. if you have less than 10k miles i would say you have a 50/50 but other than that your chances are 1% of it fixing it.
Old 12-21-2005, 07:29 AM
mn__30
mn__30's Avatar
First of all how many miles do you have on your car? You can try the solenoid, but I do agree with honda guy, It is pretty much a 50/50 chance. What I would do is call American Honda Customer service for assistance. They might help with the repairs. You have nothing to lose.
Old 12-21-2005, 07:41 PM
hondatech
Honda tech/eprom hackr
hondatech's Avatar
In the begining of this whole tranny mess, honda was telling us to replace the solenoids and it would fix them once every 50 cars...... It's gonna need a tranny.
Old 12-22-2005, 03:18 AM
flyromeo3
flyromeo3's Avatar
well it started acting up at like 80-85k miles.
I have 98k now. I've called Honda care and basically they wont honor a warranty. Even though I purchased the extended warranty.
If the solenoid doesnt fix it then ill contact honda care again and bitch some more.
The 02 models are excluded from the notoroius tranny problems.
Old 12-24-2005, 08:00 AM
flyromeo3
flyromeo3's Avatar
well then my tranny must be in that 1% because I replaced it today and it seems to have solved my problem. Shifting is alot more smoother.
Also, when i removed the old solenoid, the filters seemed to be all gunked up.
Old 12-24-2005, 08:58 AM
hondatech
hondatech's Avatar
Yeah well what was clogging the filter? metal pieces? clutch material?
As soon as the filter clogs again it will have problems.
Old 12-24-2005, 11:24 AM
flyromeo3
flyromeo3's Avatar
there wasnt any metal pieces on the filter. It looks like fluid build or something. I did rubb my finger all over it to see if there might be shavings but, i found nothing.
say it does happen again. If i take it to honda would they make me pay the full amount to fix? I currently have 98k miles on an 02 accord sedan.
