Go Back   Honda-Acura.net > Auto Forums > CL, TL, & Vigor
Thread Tools Display Modes
Old 12-17-05, 06:04 PM   #1
nijbix
Door opening problem
I have a 97 Acura 2.2 Cl, 50500 miles. I haven't had any problems until I found I couldn't open the driver door from the inside although the door opens from the outside. I removed the door handle cover on both the passenger and driver doors and found that there's a piece in the driver door that's broken. I don't know the name of this piece but it acts like a hinge (the turning motion of the door handle is transmitted to a rod which pulls the door open). What I can't seem to find out is:
a. the name of this piece so that I can order it
b. an idea of how to go about repairing it myself
I would appreciate any help on this and a recommendation on whether I should have a mechanic fix this problem. Thanks in advance!
      Registered and logged-in users don't see this ad!
Register your free account today.
nijbix is offline   Reply With Quote
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 12-18-05, 07:30 AM   #2
TexasHonda
http://www.acuraautomotiveparts.org/...prddisplay.jsp
See above link. I believe the latch handle assy is sold as a unit, but you may be able to get some of the individual parts. You'll need to remove the door panel to remove the latch assembly mounted on the door frame.
good luck
See You Down the ROW
TexasHonda is offline   Reply With Quote
Old 12-22-05, 07:08 PM   #3
nijbix
Thanks for the info...the labelled diagrams on the website http://www.acuraautomotiveparts.org/...prddisplay.jsp are exactly what I was looking for!
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
