oil leak?
Old 12-14-2005, 06:08 PM
qazxswed345
qazxswed345's Avatar
Default oil leak?
i know im leaking oil simply because i can smell it and i see its coming from the oil plug which is in snug and this is the second plug ive been through and when i get a new one it stops the problem but why does my plug keep goin bad
Old 12-14-2005, 08:15 PM
vtec-y
vtec-y's Avatar
Default oil leaks
my oil was leaking for a while too. thats why i started doing my own changes. one problem could be that your oil filter is screwed in too hard. you said that you can see oil comming out from the drain plug though, what type of bushing(spacer) are you using ont he drian plug? honda recommends a metal lock washer but i use urethane ones. they work really well. when it gets warm the urethane forms itself to the shape of the hole. (you must replace it everytime you change your oil) this stopped the leaking on my car.
you can get these things at autozone or maybe if your lucky you can grab a bag of them at home depot for wicked cheap.
i use a 14mm bushing on my accord
hope this helps,
andrew
