Keep it Stock!
Keep it Stock!
(97 CIVIC EX) I want to keep the original cd player that came with my car but also want to add subs and amp. i know i need to get a converter of some sort but i am still unsure on which wire i could connect the converter to. i dont have a manual for the wiring diagrams so i need a little help. thanks.
when i was running my stock deck 4 years ago i tapped directly into the speaker wires at the rear deck. just climbed into the trunk and tapped into them from there.
You Big Dummy
Yes, just connect the line out converter to the left and right +'s and -'s of the rear speakers. It is much easier to do it that way than behind the radio. IMO, sound quality with the converter is bad. I would run that while saving up for a aftermarket deck so you can hook the amp directly the headunit's outputs for better sound.
You Big Dummy
The cars stock wiring will be two seperate wires for negative and positive. You could tap the signal directly from the rear speakers terminals and hide the converter somewhere in the trunk/hatch of your car.
Yea, you can use a line-out converter. Such as http://www.edesignaudio.com/wire_cat.php?catid=43
However, you will lose the fade ability when you hook that up to the rear speaker lines.
