anyones center console screen die?
Old 12-12-2005, 04:12 AM
br2819
br2819's Avatar
Default anyones center console screen die?
mine died a few months ago. it doesn't light up any more. everything still works but you need direct light to see it like a flashlight.
Old 12-12-2005, 06:55 AM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
The climate control? Mine went dim at times because of the winter coldness and the subwoofers sucking a lot of the power. :happysad:
Old 12-12-2005, 10:28 AM
ItsaHonda
ItsaHonda's Avatar
It's a relatively common problem on 03s and some 04s. The dealerships have been replacing the entire units under warranty, and Honda has been issuing goodwill service to some of those out of warranty. Out of pocket expense to replace the unit from Honda is $1,000+. Depending on the situation, they may cover the entire cost, or they may split it with you. Call Honda of America. There is a TSB out for the problem, # 04-027. Good luck and keep us posted.
Old 12-12-2005, 05:39 PM
blacknight07601
blacknight07601's Avatar
Yeah, a friend of mines died on hers also. It's getting replaced under warranty though. But there's a way you can purposely turn off the display if it's too bright. Press & hold the CD button for 5 seconds. You'll hear a beap, then it should go dim, or come back. For many 7th gen models it worked, but if there's a problem with the actual unit, it won't work
Old 12-12-2005, 07:04 PM
br2819
br2819's Avatar
the screen is definitely dead. i guess i'll take it in and get it fixed along with the broken lumbar in my seat. also what maintenence should i get done at 45k. haven't done anything yet so i think i need the valves adjusted but anything else while its at the dealership?
Old 12-13-2005, 06:07 AM
mn__30
mn__30's Avatar
Call America Honda Customer Service for assistance...
Old 01-07-2006, 11:49 PM
saadiqie
saadiqie's Avatar
I've already been through 2 on my '03 Accord. The first one was while it was under warranty and the other was when my car had a little over 100 miles over the warranty (therefore out of warranty). I have the extended warranty on my car (got a real good deal purchasing it so I decided to get it) so luckily I only paid $50 bucks to get it replaced (along with some other work done to it).
It's a big problem and when it happened the 2nd time I got pretty peaved...
