is it possible???? 5th gen sohc vtech head on a 4th gen sohc block??
Old 12-09-2005, 05:03 PM
91_accord
91_accord's Avatar
Default is it possible???? 5th gen sohc vtech head on a 4th gen sohc block??
is it possible?? 5th gen sohc vtech head on a 4th gen sohc block?? please someone let me know...
Old 12-09-2005, 06:52 PM
it's vtec and please keep all your 4G related engine Q's in the one thread you already started.
Old 12-11-2005, 10:59 AM
Splatch
bad as hatch
Splatch's Avatar
yes the head will work, but why
Old 12-11-2005, 01:43 PM
kurare
kurare's Avatar
clearly he wants the VTEC head inside a 4th accord :P
Dont u need a 5th gen EX ECU to run the vtec?
Not to mention of the sensors are in the same places. also a 5th gen ECU are diff i think. 96-97 use OBDII... and likely ur sensors are in different places... so that might not give u maximum fuel efficiency and stuff like that...
It gets messy once u get under the hood and start mix-matching parts like that. Swap in a JDM H22 into that 4th gen and be done with it!
