Anyone knows how to do a 4-5 lug conversion?
Old 12-08-2005, 11:09 AM
91_accord
91_accord's Avatar
Default Anyone knows how to do a 4-5 lug conversion?
I've got this 91 accord ex and I want to know if it is possible to do a 5 lug conversion on it.
Old 12-08-2005, 11:44 AM
accordsir86
accordsir86's Avatar
yes its possible, ive seen it done b4, forgot where. google it and you might find a kit for the conversion.
Old 12-08-2005, 04:28 PM
JDM ACCORD
JDM ACCORD's Avatar
you can do it if you got around 600 to 1000 dollars with you. I tried to do the same thing, a few months ago but as soon as I started searching for prices, I backed off. Search around the threads and at local tire shops and they might be able to give you prices...good luck
Old 12-08-2005, 04:52 PM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
What do you want it for?
Old 12-08-2005, 05:17 PM
JDM ACCORD
JDM ACCORD's Avatar
I guess he wants more wheel choices, cause that is the only reason I would do it..
Old 12-09-2005, 12:56 PM
janmichael
janmichael's Avatar
Default ..
here check this out. a guy i know did a 5 bolt conversion but on a 5th gen!
http://forums.torontoaccords.com/vie...=35143&start=0
Old 12-09-2005, 07:03 PM
stereo
stereo's Avatar
I did the 5 lug conversion on my 5th gen the fronts are easy should be the same for the 4th gen you just use 95-97 odyssey front knuckles and calipers off a 91-97 accord wagen with the 23t mounting brackets ( I used legend Gs dual pistion ones) as for the rear you must have disc brakes ! if you don't you have to swap it out also ,the hub to use is 97-01 prelude with a 98-01 accord v6 or teg type-r and your old caliper will mount up fine .
