Change Pollen Filter on Accord 04
should have done a search for cabin filter. little things like this have already been discussed a few times h:
here's a pdf... not the best writeup, but you should be able to figure it out.
https://www.honda-acura.net/forums/a...4&d=1128971153
pronounced tech
its the easiest thing in the world. i replaced my filter less than a month ago and if you follow those instructions its a breeze. i even did mine at 8pm a small flashlight, so you should be good.
Originally Posted by motoguy128
the hardest part is cleaning out the glovebox. It takes 5 minutes to change. It's easier than changing the engine air filter which requires tools.
