Swaybar
Old 12-06-2005, 01:11 PM
burnrubber
Nucking Futs
burnrubber's Avatar
Default Swaybar
If I put a bigger swaybar on my car, what will I gain in stability and response?
Old 12-06-2005, 01:16 PM
shonnv
7th Gen Coupe V6
shonnv's Avatar
BIGGER wont fit your, you need a THICKER sway bar.
Get a TL-S sway bar for your 6th gen and it will handle alot better plus its cheap around 60 bucks.
Search and you will find alot thread about TL sway bar upgrade
Old 12-06-2005, 02:48 PM
jschmid
jschmid's Avatar
Bigger, thicker, just semantics.
And yes, it'll improve handling by decreasing body roll.
You can go with a mild setup like a rear TL-S/CL-S alone, or you could go for a complete front/rear setup like Eibach, etc.
Old 12-06-2005, 03:16 PM
burnrubber
Nucking Futs
burnrubber's Avatar
thx guys, how long and how hard is it to change the swaybars both front and rear
Old 12-06-2005, 04:32 PM
evolution
早晨好, 先生們!™ 粉腸+ 春袋
evolution's Avatar
Not that hard, but it may be tough if your bolts are rusted.
Old 12-06-2005, 08:05 PM
jschmid
jschmid's Avatar
Yep, if you live in the "rust belt" it can be a pain. To release the nut on the endlinks, you need to hold the "bolt" part of the endlink with an allen wrench. So you'll need an open/box wrench here, rachet and socket won't work on the endlinks.
Other than that, it's pretty self explanatory.
Old 12-07-2005, 03:39 AM
burnrubber
Nucking Futs
burnrubber's Avatar
I use to live up north so it probably pretty rusty under there
Old 12-07-2005, 06:41 AM
TaekOne
pronounced tech
TaekOne's Avatar
its more a matter of trying to get beneath your car to actually reach the bolts and endlinks. other than that, if youve got all the necessary parts youre good to go.
