This is a BiG Mystery?????????
Old 12-06-2005, 11:18 AM
unknown_user
unknown_user's Avatar
Default This is a BiG Mystery?????????
This is driving me crazy,how do i stop this light in the glove compartment from staying on while the glove compartment is close(with out removing it). While im driving at night i can see it threw a little opening(yes i tried tighting the screws didnt work),i have a 91 honda accord ex, i have a couple of buddies that have the same problem, it seem like all of the honda accords from 96 and down all have the same problem,
Old 12-06-2005, 04:03 PM
vtec-y
vtec-y's Avatar
Default glove box light
i had the same problem on my 97 accord. it got fixed when i took out the bottem half of the dash to put in a new shift stick. there are 2 rollers mounted to allow the glove box to move up and down. to remove them you must locate them inside the box. (very visable on the sides, just pop them out) the door will swing down. now just reassemble it. make sure the rollers are snapped in right. thats how my light no longer shines through that crack at night.
all that is probably not nessasary but, thats how i fixed it so...good luck.
--andrew
Old 12-10-2005, 06:32 AM
96exr
96exr's Avatar
this is a common problem on accords
in my 96, the light is on tooo
Old 12-10-2005, 10:53 AM
starsixtynin
starsixtynin's Avatar
lol I have the same exact problem on my 95. I've really thought about it before because it's not too noticable in my car but it is there.
Old 12-11-2005, 02:36 AM
kurare
kurare's Avatar
lol...my 95 accord too!!
i took out the lug nutz sitting in there and it happens less...
its coz its too heavy or soething...
i'll check out v-tec's method
Old 04-27-2006, 10:02 AM
Johar
Johar's Avatar
Ahhh I see, very simple. At least for me. Same thing happened to my 94 accord. There is a little black hook which is what the actual glove compartment door locks to. You need to bend that back into its original position. It may take you a few trys, but its not too hard. Its a soft metal so its easy to do also.
Old 04-29-2006, 11:45 AM
R_Squared
LEVEL UP
R_Squared's Avatar
I have this problem in my '94 integra. i usually just stuff a couple of papers or repair receipts in the way to close the gap so it doesn't light up.
Old 04-30-2006, 11:54 AM
Nors
倍力恋
Nors's Avatar
Used to happen to me also. I thought I just had to much weight in it. Then after I took out the maglite it still happened. So I unplugged it.
Old 05-01-2006, 09:27 PM
sherwood
I missed Sean
sherwood's Avatar
i have the same problem on my G3 teg
Old 07-25-2006, 08:53 AM
cwazyboi
Legendary
cwazyboi's Avatar
hehe i got the same prob but i drive a legend
