Accord Transmission Fluid
Old 12-01-2005, 07:14 PM
skizot98accord
skizot98accord's Avatar
Default Accord Transmission Fluid
My 1998 Accord EX has a little over 100k miles on it and I think it's probably time to change the transmission fluid. I've heard that these cars don't have a transmission filter. Is this correct? Also, what type of transmission fluid do I need to put back in and where exactly on the transmission pan is the drain plug?
Thanks in advance!
Old 12-01-2005, 07:22 PM
01ACCORD
01ACCORD's Avatar
Is this MT or AT ?
100k? Yeah...I'd say your about 70k overdue!
Just dump and fill, never flush. Always use HONDA brand fluid.
Old 12-01-2005, 07:26 PM
skizot98accord
This is the AT transmission. So, I take it I can only get the fluid at the Honda dealership? What is the capacity of the AT on this car?
Old 12-01-2005, 07:27 PM
01ACCORD
01ACCORD's Avatar
Yes, dealer only.
Capacity should be in the owners manual. Don't have mine handy right now.
Old 12-01-2005, 08:00 PM
skizot98accord
So this car doesn't have a transmission filter, correct?
Old 12-01-2005, 08:03 PM
Misa
Pic Whore
Misa's Avatar
nope, no filter
drain and fill
use Honda ATF.
Old 12-01-2005, 08:05 PM
skizot98accord
One last question (and probably a stupid one), but where exactly is the drain plug on the trasmission pan (I've never looked for it when changing the engine oil)?
Old 12-01-2005, 08:29 PM
Misa
Pic Whore
Misa's Avatar
the tranny doesnt have a pan. the plug is located on the side of the tranny (passenger's side)
Old 12-02-2005, 10:02 AM
Jon02Accord
Jon02Accord's Avatar
the reason why there isnt a filter and you should not "flush" it is bc there is a "screen". if you do a flush, it will push debris thru the screen defeating its prupose. honda recommends changing the fluid every 100k mi for normal driving. i did mine at 50k.
Old 12-03-2005, 12:43 PM
skizot98accord
OK, got the transmission fluid drained (that drain plug was a B!%ch to loosen). I can fill it by removing the plug on the top side labeled "ATF" and putting the fluid there, right? The only reason I ask is that I've seen other posts where people say to fill it by using the dipstick pipe (which you can't really get a funnel to fit over the top of it).
