Hot Accord 94
Old 11-28-2005, 02:05 PM
BetterBob
Nobama
BetterBob's Avatar
Default Hot Accord 94
Hey guys, this one has me stumped. While i am driveing, even with the heat on full blast (the heat works good) my car over heats... i dont know why, could it be a bad temp sensor? But it still reads cold when the car has sat..
Any ideas
PS I dont check the board often so I might not reply for a bit...
but thatnx for any input
Old 11-29-2005, 03:18 AM
ND120883
ND120883's Avatar
First of all, when it starts overheating, pop the hood and see if its actually overheating. If its too hot you will be able to tell, the air around the engine will be signifigantly warmer than normal. Check radiator and hoses for leaks and make sure your radiator is topped off. Check the radiator every few hours to see if its losing fluid. If its not, then it could be a bad thermostat. Make sure your fans are kicking in at the right times as well.
Old 11-29-2005, 05:12 AM
sponginpunk
sponginpunk's Avatar
how bout the water pump?
Old 11-29-2005, 05:25 AM
I'd check your radiator / radiator fluid. If those are fine, I'd start to point a finger at the thermostat.
Old 11-29-2005, 06:40 AM
strykernyc
strykernyc's Avatar
yes thermostat and check the main relays.
my radiator is losing fluid but the car doesnt overheat.
Old 12-04-2005, 01:02 PM
BetterBob
Nobama
BetterBob's Avatar
thanx guys, il check those out
