What ecu is this ...??
Ok so a while back a friend gave me an extra ecu he told me it was from a 2000 SI so there for it should be for the b16 well i just won a b16a2 head from the civic si and im gonna do an ls/vtec but i need to find out if this is the right ecu to start with if im gonna get it chiped or what ever... he got it from the local junk yard and i dont know how to tell what its actually from cause it has a tag that says its from a 2000 civic but doesnt say what model... SI... soo this is what it says and hopefully you guys can help me out.
STOCK # TR1029 MODEL CIVIC
IC# 58202 ENGINE BRAIN BOX
DESCRIPTION ELEC CONT UNIT (ECU), (RIGHT F {...got cut off on the tag}
COMMENTS:
YR 2000
VIN: 1HGEM1159YL021645
LOCATED: HOLDD*
and then on the ecu its self it has in yellow paint marker tr1029 again and on the side it has a white tag with this on it...
37820-P2T-A12
Z4 1170-208191
I really hope that is some useful info..lol but if you have any questions let me know and i will try to answer them but I was really wondering what ECU this even is... and if its the right one ... or will i even need this ecu
COMMENTS:
YR 2000
LOCATED: HOLDD*
37820-P2T-A12
Z4 1170-208191
On permanent hiatus
Just a random shot in the dark, but I believe it is a 00-01 Si ECU.
If you have an OBd2b engine harness, you can use it. Otherwise, no, it is worthless.
I hate 2003 Noobs.
You are correct. P2T is 99-00 si ecu.
On permanent hiatus
Originally Posted by BOOSTED-EK
My block is a 97 ... that is obd2 isnt it?
If not... noob question... how do i tell?
I would recommend an OBD2a or OBD1 P72 ECU since it will either directly plug into your harness or will plug in with a conversion harness and will run the vtec setup just fine.
Hmm learn something new every day huh... OK soo http://cgi.ebay.com/ebaymotors/Integ...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/P72-G...QQcmdZViewItem
OK soo i just want to make sure that this is what i will need to get it running right? Will this work with hondata, crome, urberdata or what ever i decide to use? thanks for the help!!
Yes, it is OBD2, but it is OBD2a which is completely incompatible with OBD2b. The ECU will not plug into your factory harness.
