cold air intake installation help
hello.. i am new to the forums and also new to adding modifications to vehicles.. im putting in a CAI (cold air intake) into my 94 honda accord ex and am pretty much finished.. but..
when i started i pulled 2 connections from my stock hose, but the CAI only has 1 hole to reconnect the existing connections.. so i have 1 value/hose just hanging there.. need some help.. here are some pics..
thanks in advance
thanks in advance
extension pipe? what if i do get an extension pipe.. how am i going to attach it to the intake tube? is it necessary to drill a hole? what does that valve do and what would the consequences be if i just left it there?
it didnt seem to make a difference with the way my car ran when the hose was off and then when i attached it
well, I had similar problem, on my 02 accord. but instead, I had extra pipe sticking out from the intake.. so I asked the shop and they said it's ok to use tape and cover the hole. so I've been droven like that for about 2 years now... I had no problems. =]
Dude, I'll go with shonnv just to be safe. Buy that extension pipe or a three way split extension (like one of those in the windshield wiper fluid pipe underneath the hood). I had that same 94 accord ex with three small pipes conneting to the intake while my friend had a 97 accord ex with only one pipe, I dont understand why, both cars are auto i4 vtec.
thanks for your responses.. i commute about 50 miles one way and so i drove it this morning.. didnt see any problems, but i will probably see if i can get a three way extension from autozone or something..
would anyone happen to know what that value does though? it was connected to the stock intake with a long rubber hose..
also.. it seems as though my windshield wiper fluid is not coming out anymore.. i checked for leaks and nothing.. maybe it has something to do with the small resonator i removed that was connected to the lower portion of the stock intake.. i think i removed a vacuum hose from the solenoid and capped it.. that was the closest i came to a wiper fluid hose
thanks
thanks
