Titanium pistons for SOHC ...heeeellpppppp
I found out they dont have titanium pistons for sohc, so if i was to run nos or turbo how can i upgrade my pistons if i dont want to change my motor either.
you asked about titanium pistons before and raiden gave you an answer
why would you still want them after given this info?
Originally Posted by raiden571
titantium is a bimetal (i think thats what its classified as), it grabs other metal. aluminum against steel is ok. but, titantium against steel would rape the shit outta cylinder walls
Originally Posted by heinousmule
I want them because i understand they wont crack under high compression if ure running turbo
You will want forged pistons...titanium pistons will do you no good even if they did make them, because titanium is a bimetal, and would not go well with our block.
I just happened to state it...wow i feel smart
hey you could allways buy kevlar pistons, that way they would be bulletproof!!!
j/k if your lookin for good pistons go with what is tried and true, dont try some new shyt just becuse it has a fancy name,
titanium light and strong compared to other metals BUT if it was realistic then every racer in the world would allready be using it, and lets not forget it would cost about 5000.00 per piston due to the high cost of titanium!
