civic gauge pod problem!
i just got my gauge pod in the mail(autometer dual gauge pod),any when i ordered it,it said it was for all 96-00 civics(i have a 4dr 2000).now that i received it,it says for 2dr 96-00 civics.i tried the test fit it and it kina fits but would need some trimming and it doesn't look like it is going to wrap around the A-pillar!should i send it back or keep it because the 2-door pillar is that same as the four door??if i need to get another one,are their ones out their for 4-doors??
my bum is on the swedish!
I'm 99% sure they're different.
I know the mirrors are different. plus, the coupe doors are longer, so it would make sense that the a-pillar panel is different due to the longer doors.
email them first, then send it back for the 4-door pillar. or get one of those dual pod holders that replaces your gauge cluster peice
the pillar might be different, but then its nothing a heat gun cant fix. heat it up and wrap around it. since u have a 6g civic, u should of went with the dual gauge bezel pod replacement instead. much more cleaner look and the gauges sit right there next to ur stock ones.
