Loud thumping/knocking noise when braking
Everytime I go to brake to come to a stop, I hear a loud thumping, like a loud knocking, noise coming from the front of the car. It's not consistent to the point where it will happen all the time to where you can guess it's next knock. I don't believe it has anything to do with the rotors because braking is smooth. Only problem is the loud thump/knocking noise.
I removed the lower ball joints a few weeks ago to replace my transmission, and reinstalled them like normal. Could one of the LBJs be producing this noise?
I also removed my traction control bar thinking that was the source, but it wasn't.
Any suggestions?
Any suggestions?
Honorary Moderator Alumni
Is it a constant thumping when you are braking? Or just one thump?
Autocross Help Page
Autocross Help Page
Could be:
warped rotors
cv joints going bad
wheel bearings?
warped rotors
cv joints going bad
wheel bearings?
Autocross Help Page
Autocross Help Page
warm butter on toast
Does it only happen when you're going slow and almost at a complete stop? That could be a sign of severly warped rotors. Also test your CV joints. Take a left and right hand turn slowly and then reverse while turning left and right.
Originally Posted by CivicSiRacer
Could be:
warped rotors
cv joints going bad
wheel bearings?
warped rotors
cv joints going bad
wheel bearings?
cv joints bad- possibly
wheel bearings- i don't think so either, otherwise i'd hear noise when going driving and not just when braking.
Testing my CV joints only requires me to "Take a left and right hand turn slowly and then reverse while turning left and right"? Should I be braking at all during this time, or just driving normally? Slowly?
Originally Posted by Kestrel
Did the thumping occur before you redid your LBJs?
