What is Error code 41 in 97 Civic
Old 10-23-2005, 06:57 AM
Honda Civic 97
Honda Civic 97's Avatar
Default What is Error code 41 in 97 Civic
I have a 97 Civic with the Check engine light on. I shorted the bue connector and the only code stored is 41. Does anyone no what this code is and how to fix it?
Old 10-23-2005, 08:50 AM
teg92
WHAT OK YEAH!
teg92's Avatar
code 41 i think is the o2 Sensor Heater. Someone correct me if im wroung
Old 10-24-2005, 07:25 AM
JimBlake
JimBlake's Avatar
Specifically, the heater for the FRONT O2 sensor.
Unplug the sensor, get an ohm-meter. Measure the resistance between the 2 same-color (black?) wires. They should be 15 to 40 ohms. Then check if either one has continuity to ground. They shouldn't. If it fails any of this, get a new sensor.
If those checks are OK, then you gotta start looking for screwed-up wiring in the car.
Old 11-01-2005, 10:12 AM
swaggs21
swaggs21's Avatar
or a new ECU, my ECU ate it when I had this error, took like 6 months to track it down....
