92 Vigor- got ABS code 1-2 -(Pump Motor Circuit)or Motor Relay fuse???
Thanks everyone for reading,
My abs light was on so I jumped it and got code 1-2 which is the Pump Motor??? I have googled and checked all acura forums and cannot find anything about this. Also, it says to check the Motor Relay Unit Fuse which could be the problem. I know exactly what and where this is but how do you check it? It's that big fuse but you cant tell if its bad or not like all the little regular fuses.
So I guess my 2 questions are:
1) What and where is the Pump Motor and if possible you could explain how to change it.
2) I hope the problem is the Motor Relay Unit Fuse but before I go buy one to see if thats it and not the Pump Motor is it possible to tell if this fuse is bad?
Thanks again everyone!
MIke
MIke
