Most tire on the ground?
Old 09-09-2005, 08:20 PM
ED9man
driver
ED9man's Avatar
Default Most tire on the ground?
What is the widest/tallest wheel I can fit on my 88 CRX with no rubbing issues/ bad speedo issues/ artifical tall gearing issues? 15x7? The more rubber on the ground the better.
Old 09-10-2005, 06:47 AM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
You can fit 215/40x16" tires on a 16x7" 42-44mm offset or 16x7.5" 42-43mm offset (pushing it) wheel. Speedo will be off.
You can probably fit 225/45x15" on the fronts and 205/50x15" on the rear of a CRX but it will be tail happy.
Autocross Help Page
Old 09-10-2005, 07:18 AM
ED9man
driver
ED9man's Avatar
Thanks. I have a couple more. How wide are the stock tires in inches? They are 185/60-14 Also is there anyway to recalibrate the speedo? Would the 16's hurt acceleration significantly? And 16x7's with a 45 mm offset would have no rubbing issues?
Old 09-10-2005, 07:30 AM
CivicSiRacer
The 1st set of numbers on a tire is the width in mm. So convert to cm and 1 inch = 2.54cm
You can recalibrate the speedo but it's not worth it. Cause what's going to happen when you go back to stock size. 215/40x16" will throw your speedo off by about 5-10mph.
Autocross Help Page
Old 09-10-2005, 09:04 PM
ED9man
driver
ED9man's Avatar
thanks. The only reason I asked about the 45mm is the rota slips which I like only come in that size. Which means that with that offset it'd probably hit the fender right?
