need help turbo wont go into boost
Critter SIR-T
ok so i have a b16a jdm with crower turbointernals the head and gasket are stock jdm. the bottom end of the motor was built for boost. i put it in the shop on mon to get the turbo installed and tuned. there were no problems with the car before it went i9n. now there is still no problems exept when the turbo spools *at least i can hear it( but there is no power untill arround 6000 rpm i put on a dragg kit from turbonetics with a front mount intercooler greddy profec b boost controller type s bov and a delta mark 2 waste gate. the turbo is getting oil and returning it well.and the motor isnt overheating and the motor is handeling the boost well. the motor just pulls irraticaly i checked all the vaccum lines and there are no leaks. there is oil everywhere onthe back of the motor. my friend says he thinks they blew the head gasket but if that was the case wouldnt the motor run crappy.
Critter SIR-T
maby but i replaced it about 2,000 miles ago along with timing belt head gaskets water pump oilpan gasket valve cover gasket exhaust and intake gaskets yada yada yada
Critter SIR-T
he hasent been able to tune the car yet thats gonna be done tonight so well see. the test runs were great he kicked 15 psi outta it and it handeled it fine its under 5 now so could it be that maby the boost is set low??
Critter SIR-T
ok so the oil feed line for the turbo was loose as hell the car has been returned to the shop for compleation and tuning. the waste gate was set low so that i wouldnt overboost. so thats the low down.
ACCORD & CIVIC TUNER
Originally Posted by critter sit-t
the bottom end of the motor was built for boost..
Originally Posted by qtiger
You ran 15 psi on a block with stock sleeves?
Originally Posted by 90sicivic
does that answer your question?
