| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Starting/Ignition trouble with my 1996 acura integra
| Sponsored Links | ||
#2 |
on my 94 rs i had that problem once...I think it was because after i turned off the engine i moved the steering wheel and that messed with the ignition. I moved the steering wheel around a bit (don't force it, just sort of wiggle it), and try the ignition.
94 RS Teg, stock
#3 |
Thanks for the suggestion. I did try it but no luck. It did stop working after I fiddled with my steering wheel position after I had turned off the ignition though. Is there any way to reset it back to it's original setting? Or is there a reset button somewhere to indicate that use the new steering wheel position for future ignition purposes? Appreciate any response.
Thanks, |
#4 |
your ignition switch is probably broken. do you have tools like a digital multimeter? if you do, i will post up on how to test the wiring to confirm its switch.
98 Adriatic Blue Integra LS Sedan 01 Electron Blue Prelude Base 00 Anthracite Metallic Civic EX |
#5 |
I don't know of any way to reset the wheel to it's original setting(without starting up the ignition)..it just started up for me after i fiddled with the wheel...Oh and my CEL did NOT go on at any time so you probably have a different problem
94 RS Teg, stock
#6 |
Hi,
I can borrow a digital multimeter from someone (or, in the worst case, I will just go and buy one). Could you please let me know the wiring test to confirm that its the switch which is giving me the problem. I appreciate it. Thanks, >your ignition switch is probably broken. do you have tools like a digital multimeter? if you do, i will post up on how to >test the wiring to confirm its switch. >__________________ >98 Adriatic Blue Pearl LS Sedan |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
