| Do It Yourself This is where you will find step by step instructions so you can Do it Yourself! |
Thread Tools | Display Modes |
#1 | |||||||
Need help!Valve adjustment '96 2.5TL-Help
| Sponsored Links | ||
#2 |
hey, well for me when i had to do it, i had to take driver side wheel off and there was a bolt in the crank pully had to turn it counterclockwise until cylinder 1 was tdc... theres a mark on the crank pulley and on the cam gears... now im not sure how it is becuase u have a different motor but i could find out if it was the right clylinder working on was by pulling on the rocker arms... it would be loose if the cylinder was on tdc... wat you really should do is get a manual for the car to work on and see how it is... also get a feeler gauge for this.. as it has the numbers on there... like the .026 and .30
also mine is .07-.09 on the exhaust if i remember but the gauge didnt have .07 or .09 had .08 so that might be the case with you too find the tolerence for it too... |
#3 |
lots and lots of fail
you would be well advised to buy a service manual
2003 San Marino Red Accord Coupe EX-V6 6MT IMM244k miles ![]() www.lemons300zx.blogspot.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
