S2K Turbo kit
Old 07-28-2005, 06:35 PM
B18C Turbo
B18C Turbo's Avatar
Default S2K Turbo kit
My friend is making custom turbo kits for the s2000. The kit includes
XS Power T3/T04E 57 trim .63 exhaust .60 compressor
Cast Iron Manifold
38mm Wastegate (9 psi spring)
Custom 2.5" downipe mandrel bent
Tuner Toys Oil line kit feed+return
Chrome polished 2.5" Intercooler piping
FMIC 28x9x3 2.5" inlet + outlet
Greddy Type-S Blow off Valve and flange
Various brackets, T fittings, vacuum lines, hoses+clamps
RC 440cc Injectors
Custom Neptune Stand Alone EMS pre-tuned for 9psi (no Need for FMU or Missing link!)
Walbro 255lph In-take fuel pump
All neccesary metal gaskets and zinc bolts
How much would you pay for these kits?
Obiously they are far superior than the REVHard kits because of the EMS.
Old 07-30-2005, 06:53 PM
AP2
Moderator Alumni
AP2's Avatar
I'd like to see the manifold.
Old 07-30-2005, 07:00 PM
B18C Turbo
B18C Turbo's Avatar
The manifold is straight from REV hard, its a cast iron piece. Turns out we can't get the netpune program to work so were just going to use an FMU, missing link, and fuel pump. We are going to offer this as fuel management for now until UBERDATA has worked its magic for the S2K.
Old 08-01-2005, 06:47 AM
shivers
Moderator Alumni
shivers's Avatar
How do you figure this is going to work? The s2k ECU is not flashable, reprogrammable, or chippable.
2005 s2000
Old 08-01-2005, 06:10 PM
B18C Turbo
B18C Turbo's Avatar
yeah, were just gonna wait for uberdata. For now, vortech 12:1 fmu, missing link, 255lph fuel pump.
Old 08-02-2005, 06:24 AM
Asahi
Administrator
Asahi's Avatar
I wouldn't hold my breath for Uberdata for an S2k. Uberdata and even hondata are ODB1 specific. Hondata used on OBD2 cars is even YEAR specific much less model specific.
Good luck with that.
Old 08-03-2005, 09:24 AM
MathGSR
MathGSR's Avatar
xspower turbos :down:
bad bearings
Old 08-07-2005, 05:20 PM
B18C Turbo
B18C Turbo's Avatar
XS power bad bearings? Are you joking?
1) XS power doesnt make any ball bearings turbos, they are bushings
2) How would you know?
3) XS power turbos use all GARRET Internals
Old 08-08-2005, 12:42 PM
Josh M
Josh M's Avatar
Isn't XS power the ebay brand? Either way........XS Engineering isn't all that great either. I would probably pay 1500 for this
Old 08-08-2005, 04:51 PM
VTEC-Power
VTEC-Power's Avatar
XS Power is a eBay brand and XS Engineering makes some great products.
