How do I replace front brake pads for 98 Honda Civic
Old 07-14-2005, 05:03 PM
stock1
stock1's Avatar
Default How do I replace front brake pads for 98 Honda Civic
I am a college student so I cannot afford to pay to get the front brake pads of my 1998 Honda Civic Replaced. Could somebody tell me how to do it or email where I can find the information. Thanks so much for all your help and God Bless to all.
Old 07-14-2005, 05:29 PM
westcoaststyle
Still here... sorta...
westcoaststyle's Avatar
Remove the wheel
Use a 12mm wrench to remove the lower 12mm bolt on the caliper
Flip the caliper up
Pull the pads
Put in the new pads
Flip the caliper down
Install the 12mm bolt
That's it.
Old 07-14-2005, 05:36 PM
TeHJuSTiN
NAM #0001
TeHJuSTiN's Avatar
Originally Posted by westcoaststyle
Remove the wheel
Flip the caliper up
Pull the pads
Put in the new pads
That's it.
He/She will probably have to compress the caliper back in to fit it over the rotor with the new pads.
Old 07-14-2005, 05:49 PM
CivicSiRacer
Honorary Moderator Alumni
CivicSiRacer's Avatar
Yeah literally takes like 15 minutes per side if not less. Compress the piston back in with a c-clamp or Quick Clip.
Autocross Help Page
Old 07-14-2005, 06:15 PM
stock1
stock1's Avatar
Thank so much guys, I am a girl so it might take me longer then 15 minutes per side, but I am sure I can get it done, only car I have, Not saying because I am a girl that it will take me longer just that I have never done anything like that, only changed my tire, so I should be ok. God Bless to you all
Old 07-14-2005, 07:51 PM
CivicSiRacer
If you are in the PA area I can help you. It's actually easier than it looks. I kicked myself for not learning it sooner
Autocross Help Page
Old 07-14-2005, 08:37 PM
foot
foot's Avatar
Being a girl should have little to do with not being quick about it. Nobody is born knowing anything but how to eat and crap.
You SHOULD crack the bleeder screw before you compress the piston. It keeps all sorts of contamination from being shoved back up there. You'll probably be fine if you don't, though.
Old 07-15-2005, 07:32 AM
westcoaststyle
Ah... a technicality. :reechy:
