VIDEO...drag strip-> me (swapped civic) vs. eclipse GS
Click here to see Video
after many many runs this was the best
This is the slip...
R/T: .6038
60': 2.429
330': 6.499
1/8 ET: 9.9209
1/8 MPH: 71.53
1000 ET: 12.8983
1000 MPH: NONE
1/4 ET: 15.4218
14 MPH: 88.97
..i'm thinking that i'm peeling out too much at the line and that my launch should be better, the shop where i got the swap said i should be in the 14's but i dunno...
opinions plz
PS..current mods are DC Sport 4-1, SRI, Exhaust, 16" Konigs wrapped by Firestone FUZIONs..also got a valve-job done on the motor (33k miles on it)
Dude.... Ditch the 16's and get those 60's down to at least 2.2's.... and you SHOULD bee like a 14.9
Practice makes perfect though
BTW:.... what motor did you swap in??
-Joe
-Joe
-Joe
-Joe
ditch the 16's for what size?..
b18c1 (GSR motor) :irock:
well... Iwould go with 14" rims for racing. Maybe 14" steelies. Thats what I run all the time. Your Car with a B18C should be haulin some butt. Maybe mid 14's actually. 15.4 seems a little on the slower side.
My 91' Integra RS went a 15.43@88.00Mph all stock except no muffler on a 2.232 60' . No weight reduction or anything.... and that was on 14" rims all around. I'm sure if I put a set of 16's on there... the time would drop a few tenths. Also.... what tranny are you running? I Assume the GSR tranny?
-Joe
-Joe
k i'm really thinkin about gettin some 14 inchers cuz alot of ppl are tellin me that the bigger wheel does make a difference.
do you honestly TRULLLY think that 14'' would help me? i really need to kno so i can go through with this, if so how much would it help?
PS- i wanna hit 14's so bad
... 16'' is perfect.. for racing..and if you wanna hit 14's bad.. get tuned.. and a high flow cat or test pipe if u dont have one.. what clutch u running in there.. Also.. since its a gsr.. in that car.. seriously.. launch at like 3500k and feather the clutch.. until after 1st.. i dont mean granny it but watch your spin out..88 = high to mid 14's..btw
Also, 88mph is good for high to mid 14's? Not on a FWD car. It's usually good for low 15's, high 14's if you can really drive (or are using slicks).
Yeah, I need to get me another 14' tire so I can run my EF9 Si Civic. I should be able to hopefully run a high 14. B16A1 swap, stock clutch, DC sports 4-2-1 header, short ram intake, thermal research cat back. I need my fr/rr brakes & master cyl done then I'm hitting capital raceway. I'll problably launch @ 3000-3500 since B16's doesn't have much tq.
