My rear doesn't ????
What's up everyone. I have a quick question I went to fill my winshield washer fluid up & then I went to use my back wiper to clean my window.
You can here the motor working but nothing is coming out. So could it be my motor. I checked the tubes that's running from the bottle on the driver side.
I've only had GS-R for a month. I thought about just going to dealer but I know they're expensive. Thanks
I'M SO JDM, I HAVE SARS
1. if you goto a local auto parts store, they should have some sort of soluble lube you can add into ur windshield washer container under your hood. his thing costs about $2.49.
2. Go through the plasting piping to see if some/any gunk is clogging it. This takes longer, but must be done to get aroung the problem if step 1 fails.
3. Buy cheap plastic piping and replace the old one all together. (make sure you dont loose any of those lil black adaptor thiggys, cuz then its gonna get messy)
Apathy Kills
This is not an agonizing problem to fix.
Get a straight pin and clean out the little metal nozzle inside the rear washer housing. Then give it a few test squirts.
9 times out of 10, that will solve the problem.
Oh, and as an FYI: The Integra uses one tank for front and rear squirters.
