car wont start
car wont start
alright so got a compression tester from a friend (my cars been burning oil bad) and took the plugs out and ran the compression test it was 125 across the board!! SHIT haha it has 8.5:1 pistons in it... but anyway added some oil on top of the piston to seat around the ring tryed it again and the compression was 170 then 150 twice so my rings are f**ked up.. but alright put the plugs back in and plugged the fuel pump back up and the car wont start
... took the plugs out again cleaned them off made sure everything was plugged back up ... still wont start.. whats goin on?
Apathy Kills
I assume the motor cranks over on the starter?
It's either fuel or spark.
If the ignition is firing when you turn the key, then I'd check the fuel pump connector.
yes you are correct just keeps turning over haha... i checked that... maybe i flooded it trying to give it some gas?... who knows ill try it again in about an hour or so ...
