I suck at diy (need shock help)
ok so i ran into a little problem putting in my rear shock. I snapped the bolt on the LCA that holds the shock in. I'm sure some one has ran into this problem before. What should I do? The darn thing is seized in too.I was thinking about cutting out the bolt and burning the bushing out and replacing the bushing and bolt. Is the bushing replacable or is this not possible? Any other solutions would really help. I already tried PB Blaster and brute force and my best friend mr. hammer and mr. vise grip. Is replacing the LCA too dramatic?
Black Pearl
Good luck!
i'm kinda thinking about doing this myself again... I'm not sure. I have all the tools at work and the parts guy comes by like everyday anyways. I can just throw my order in. But then again I do get labor for half off ($35/hr). Well I guess if i want to learn something I should just go for it. Anyways thanks for the help.
Life after death
http://www.team-integra.net/sections...ArticleID=1025
Check if you can see that article, it might help.
On permanent hiatus
Originally Posted by SP00NFed
happens to everyone that trys to do there rears....all honda's have that problem
Black Pearl
Originally Posted by Shmoo
Never happened to me on any of the three suspension jobs I have done. h:
Originally Posted by carta79
if you're going to try to get it out with brute force, do this:
- unbolt the entire LCA, and bring the shock and LCA out as one piece. the other two bolts on the LCA don't seize like that shock bolt does. any decent impact wrench should get them out.
- find yourself a strong drill bit that can handle drilling forged steel. it should be approx. the width of the bolt, and it should be a strong drill.
- mount the LCA down in a vice or something so that will it will not move.
- start drilling the bolt out, from the snapped end.. if you have a grinder, it's not a bad idea to grind off the welded nut, so that you can drill from either end of the bolt. this will also help in case you're worried about going off track and drilling into the bushing.
it will take some effort and a little time, but if you have a steady arm, you'll save yourself any extra work of replacing the bushing, and your method of attack focuses on just one point.
this is what i had to do for both rear LCAs and the only extra thing i had to pay for was new bolts.
:blue: :blue:
Reno is on the right track, but I would suggest that you use a significantly smaller drill to start a "pilot" hole- possibly a 1/8" drill bit. This will allow for a truer bore with the larger drill bit.
As far as replacemnet bolts, my local NAPA store had everything I needed when I did my rear suspension.
If you know someone with a drill press that is the way to go.
Patience will be your greatest ally. :blue:
yikes..
Are you trying to replace the shock? If so you should just shave off the bolt that is welded onto the shock and then slide off the rest of it right out. No need to burn the shit out of the bushing if your trying to replace the shock. I just woke up so sorry if someone else thought of this b4 me. I did not read the whole thing. Anyways,, It happend to me as well and man it sucks. Just shave off the bolt on the other end if your replaceing the shock. Goodluck.
