idle drops too low when car is warm
Old 06-04-2005, 11:21 PM
R_Squared
LEVEL UP
R_Squared's Avatar
Default idle drops too low when car is warm
Just like the title says. My '94 GSR idles high when cold (1500 rpm or so), then drops to 900-1000 rpm when its slightly warmed up but when I am in traffic and its hot or the car has been running for a while, my idle drops to like 200 rpm. I don't know how it even continues to run at this speed. What's the deal?
Old 06-04-2005, 11:27 PM
Brar
Brar's Avatar
my 90 ls does the same thing, nothing big just some idle thing nothing really important just rev it
Old 06-04-2005, 11:30 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Firstly, clean out your IACV.
If that doesn't improve anything, adjust your idle adjusting screw and check your fuel injectors.
At least, that is what it tells me in the factory service manual.
Old 06-04-2005, 11:32 PM
Brar
Brar's Avatar
but is it REALLY neccessary to do this? will not doing this cause any damage?
Old 06-04-2005, 11:37 PM
Provocateur
On permanent hiatus
Well, no. I prefer a smoothly running car, so I would do it if I were you.
If it isn't taken care of, the problem will get worse and you will end up stalling everytime you come to a stoplight. It may even create new problems, so I strongly recommend that it is fixed; not because of neccesity, but because of the annoyance factor.
Old 06-04-2005, 11:39 PM
R_Squared
LEVEL UP
R_Squared's Avatar
I've already taken off the IACV and cleaned it once since I got the car (about 6 months ago). I guess I could mess with it again...
Old 06-05-2005, 02:14 AM
94civicEX
I got worms.
94civicEX's Avatar
Are you sure you aren't misreading it? You should be idling at 700 +- 50rpms.
99 Integra GSR
06 TSX
duck squad member #00003
Old 06-05-2005, 03:23 AM
R_Squared
LEVEL UP
R_Squared's Avatar
That's a little bit lower than the proper idle speed...It's barely idling enough to keep the car running.
