H&R Sport springs and what shocks ?
im thinking of dropping my car with the H&R Sport springs (1.75/1.5 front/rear)
now the question is, what shocks should i get ?
i was thinking koni ?
did a little research and found that koni yellows will make it even lower than 1.75/1.5 ?? if so, by how much ? also, at what dampening setting should the yellows be on to be able to correctly handle the springs without damaging the shocks ?
what about the koni reds ? i don't know too much about those, so edumacate me
how bout the agx's ? will those make the car even lower ? dunno much about those neither
i want to keep it right around 1.75/1.5, don't want to go TOO low ya know
also, any camber kit needed ? or would a toe alignment will do for the front ? what about the back ? i'v heard of adding washers ?
i have HR sports running with kyb agx. Shocks wont make your car lower. the agx's are great to ride on.
and yes a camber kit will be needed as well as a toe alignment. when i went in, my camber spects were at -2.0 and -1.98 in fronts and around -1.7's in the rears. People say these specs are alright but if you dont want to destroy your tires, a kit is recommended. These specs are good if you are going to the track and race your car but not for daily driving.
i still need a camber kit..hehe
I have H&R Sport Springs and KYB AGX shocks on my 97 Integra. Not sure about anyone else but my drop ended up being 2" up front and 1.75" in the back. You will most definitely need a front camber kit. I listened to everyone say you can get by without one but unless you like shredding tires, buy it anyway. I have to do the install twice because of that.
Here's a pic of the result with 17's. All in all I love the combo of the two. No complaints.
nice drop :thumbup:
KYB AGX are right around my price range, so i might go with those
what camber kit did you use for the front ? how about the back ?
i'm gonna go with 16s instead of 17s though
Originally Posted by minh
nice drop :thumbup:
I did replace the upper shock bushings once since the started to wear and squeak. I love the setup, you get what you pay for.
Life after death
I have Neuspeed sport springs with no camber kit. My tires are a whopping seven months old with hardly any wear.
That drop looks more like a "race" drop then a "sport" drop.
I
I have the H&R/KYB combo as well, with a skunk2 front camber kit. After it settled, I'd say it's almost 2" front and 1.75" rear as stated above. You don't need a camber kit for the rear...if it's that bad, just use the washer trick and save some money.
