Getting my ECU programmed
Old 04-29-2005, 09:50 AM
Kabooki
Kabooki's Avatar
Default Getting my ECU programmed
got a few questions....
What are the sizes of the stock injectors?
he needs to know my max boost setting (i guess i'll never run more than 10psi) Does it work fine for anything under that? Or should I tell him a lower psi?
He is going to set a shiftlight (CEL hack thingie i think) What rpm should i set?
Is it safe to adjust the rpm for vtec? What is default?
Old 04-29-2005, 10:02 AM
Snoopy
been there done that
Snoopy's Avatar
if i were you i'd get something programmable so you can change settings whenever you want
Old 04-29-2005, 11:51 AM
Kabooki
Kabooki's Avatar
This chip can be reprogrammed, but i dont have the prom burner. This guy will do it for free so i dont need a eprom flasher. I just want to get this thing up and running with the turbo, I dont plan to keep tuning to squeeze every HP out of it I can.
But I really want to know what is the factory injector size? ?cc
Old 04-29-2005, 01:26 PM
jeterkm02
hatchbacks r my anti-drug
jeterkm02's Avatar
stock injectors are 240cc's
are you using uberdata?
Old 04-29-2005, 09:52 PM
Kabooki
Kabooki's Avatar
i have no idea what this guy is gonna use...
Old 04-29-2005, 11:23 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
That is probably not a good thing....
Sounds to me like an ebay special preburned chip. Is he at least going to tune it on a dyno before burning the chip or just make you one from 2,000 miles away without ever meeting you or seeing your car/setup?
