swap
Old 04-28-2005, 02:11 PM
AliasNeo
AliasNeo's Avatar
Default swap
hey, i was looking into swapping the motor... i want to get a motor that would do about 160 hp stock with tranny and all that stuff to do a complete swap...
what engines should i stay away from and what should i look for?
i want a DOHC VTEC for my civic, its a 96....
and could someone please explain to me how to do a compression test and what a LSD tranny is?
could i do the swap with a couple of tools and a couple of car jacks?
also id like to keep this under 2500 if possible
thanks
Old 04-28-2005, 02:16 PM
Hon
Hon's Avatar
look into the b16's
Old 04-28-2005, 02:49 PM
turbo_pimp10
turbo_pimp10's Avatar
thanks
yea look 4 b16s.....b16a2 is best....i think
Old 04-28-2005, 02:51 PM
AliasNeo
AliasNeo's Avatar
could i do the swap with a couple of car jacks, some friends and stuff like that?
Old 04-28-2005, 03:09 PM
http://www.c-speedracing.com/howto/b18cswap/swap4.php <--- look into that
also if you want atleast 160hp to the wheels then look for a B18C GSR atleast.... its 180 or so to the fly...
The b16 may be putting out 160hp to the fly but uhhh... i cant recall the dyno sheets ive seen for it in stock form to the ground...
so yeah id go with a b18 engine *vtec or not*
Old 04-28-2005, 05:09 PM
oscar_425
Got V-TEC??
oscar_425's Avatar
yup.. go with a B18.. dont buy a B16, they're not worth it...
Old 04-28-2005, 05:37 PM
AliasNeo
AliasNeo's Avatar
arent those motors like above 2500? with tranny and all the other good stuff?
Old 04-28-2005, 05:48 PM
mini-me civic
mini-me civic's Avatar
im gettina b16 2nd gen for 1200 wit everythhing xcpt rear mount and axle.. is dat a good deal??
Old 04-28-2005, 05:53 PM
oscar_425
Got V-TEC??
oscar_425's Avatar
mm it depends... if u get a B18c/c1/c5 they are $3000 or more.. but a B18b is probably around $1500 and it has more torque than a GSR engine.. I would go with that one because is not very expenseive and it's very good to boost it or to put a vtec head on it...
Old 04-28-2005, 06:02 PM
beeek9
BeeEK9-R
beeek9's Avatar
A compression test is a test that show if their is some thing wrong with engine combustion chamber, like crack block, worn piston ring or piston, blown gasket and more. You need to check the spec on the engine.
LSD is the greatest thing to have if you wanna tackle the coner you get more traction on the coner and if you have a rear wheel drive car helps a lot on drifting. It hard to explain how it work, so you just have to look it up
