Bad Throttle responce, boggs a lot?
Old 04-25-2005, 05:38 AM
Running925
Your Powder Coater
Running925's Avatar
Default Bad Throttle responce, boggs a lot?
Hey guys, just started having this problem a couple days ago, when get on the gas the thing acts like it's dieing. Starts to bogg as soon as u get the gas. I did notice if i just barly touch the gas, it will go without a problem & it will rev all the way out.. it's just that it take forever to do so.
I'm wondering if my TPS went bad or something & just isn't dumping enough fuel to compensate for the amount of air that i'm allowing in when i open throttle up.
what u guys think?
Old 04-25-2005, 05:44 AM
pomansouth
pomansouth's Avatar
I think that your timing may be off, do you have cam gears. Also too much air and not enough fuel will hurt it as well. Check the tps with an voltmeter. Your helms should have a way to check it.
Old 04-25-2005, 05:51 AM
Running925
Your Powder Coater
Running925's Avatar
I highly doubt my timing being off, my timing belt is still in new condition & perfect tension on it. It was runnin fine the other day, boostin like normal & then all the sudden it's just not responding right.
Old 04-25-2005, 07:56 AM
Civic2Scooby
Civic2Scooby's Avatar
voltmeter on the TPS.
Old 04-25-2005, 08:01 AM
Running925
Your Powder Coater
Running925's Avatar
I'll check it out when i get home from work.
If thats not the problem tho, what else would u suggest?
Old 04-25-2005, 09:04 AM
twinring
twinring's Avatar
Does sound like a TPS problem from here. I know it may seem a bit grave but
if you arent throwing any codes. (not sure what you are using for fuel management)
I suggest you do a compression test of all the cylinders. also check the oil dip stick and the radiator and see if you got any coolant in one, or oil in the other.
Old 04-25-2005, 10:58 AM
Running925
Your Powder Coater
Running925's Avatar
Motor is sound. Did a compression test a couple weeks ago to make sure my rings sealed up nicly which they have.
Old 04-25-2005, 12:08 PM
Omniscient
warm butter on toast
Omniscient's Avatar
This happend to my 1.5l right after I washed the bay. It died for a good two hours untill it dried out. Then it bogged down when I tapped the gas. Then it had a hard time starting. It went away when I replaced my fuel filter. Then It all led up to a blown head gasket. Not sure if that's your problem.
Old 04-25-2005, 12:14 PM
Running925
Your Powder Coater
Running925's Avatar
Your issue sounds like you got your distributor wet & then by the time u replaced your fuel filter it was dried out & your head gasket probly wasn't related either h:
Old 04-25-2005, 12:17 PM
Andy
Hybrid Forum Moderator
Andy's Avatar
If you slowly build the engine with the gas pedal barely pushed does the engine still make full boost? Sounds like it might be a leaking IC pipe. Don't rule out the simple stuff though, throw a timing light on it and check where your ignition timing is, check the plugs and make sure their not fouled, check your cap and rotor that nothing burned out.
